Network Management
  • 1.  CX-6100 SNMPWALK command not working
    Posted Jan 31, 2025 05:21 AM
    Hi, so I am trying to run "diag utilities snmpwalk oid ifdescr" on a CX-6100 and I get the error, "Timeout: No Response from localhost." I have tried a couple other OIDs derived from MIB files I found for the CX, but they keep returning the same error. I am not sure if there is anything else that needs to be configured or if it just not supported for this switch.
    Firmware: PL.10.13.1040
    Model: JL675A
    Any help is greatly appreciated.
  • 2.  RE: CX-6100 SNMPWALK command not working
    Posted Feb 04, 2025 08:43 AM
    Do you have snmp server enable in switch?
    (cli: snmp-server vrf default)
    Jori Luoto
    AV-IT Specialist
  • 3.  RE: CX-6100 SNMPWALK command not working
    Posted Feb 04, 2025 08:46 AM
    Oh and another thing: On top of running snmp-server you need also proper community name there in command!
    Jori Luoto
    AV-IT Specialist
  • 4.  RE: CX-6100 SNMPWALK command not working
    Posted Feb 04, 2025 09:13 AM
    Edited by charles470 Feb 04, 2025 09:18 AM
    I found out that I was missing the SNMP community string at the end of the command after the OID part "community ???". I also used public as a community string for testing and was able to run the command. Thanks for the help!
