AOS-CX Switch Simulator
CX-6200 log LLDP Question, please advise
  • 1.  CX-6200 log LLDP Question, please advise
    Posted Feb 10, 2025 06:00 AM
    LLDP log1. Under what circumstances is LLDP added, updated, or deleted?
    2. This device is connected to CX-6200, and the LOG determines why the network keeps generating LLDP messages
    3. I have set up a CX-6200 and connected it to a laptop. I want to test the LLDP, add, delete, and update status.
  • 2.  RE: CX-6200 log LLDP Question, please advise
    Posted Feb 12, 2025 05:51 AM
    LLDP (Link Layer Discovery Protocol) is a standard protocol used to advertise and receive network device information. Here's how LLDP behaves on ArubaOS-CX:
    1. When is LLDP Added, Updated, or Deleted?
    • Added: When an interface is enabled and LLDP is active on the port, the switch will start sending LLDP advertisements.
    • Updated: LLDP updates occur periodically (default 30 seconds) or when there is a configuration change (e.g., VLAN changes, new neighbor detected).
    • Deleted: LLDP entries are removed when a neighbor stops sending LLDP packets or when the interface goes down.
    2. Investigating Frequent LLDP Messages in the Logs
    • Check the LLDP timers:
    show lldp configuration → Verify advertisement intervals.
    • Monitor LLDP Traffic:
    show lldp neighbors → Check active LLDP neighbors.
    show logging -r | include LLDP → Look for LLDP-related logs.
    • LLDP Debugging:
    debug lldp → Monitor real-time LLDP events.
    • Check for Misconfigurations:
    • If LLDP-MED is enabled, some devices might trigger frequent LLDP updates.
    • Spanning Tree Protocol (STP) changes can also cause LLDP messages.
    3. Testing LLDP Add, Delete, and Update on CX-6200
    • Add LLDP:
    • Ensure LLDP is enabled:
    config
    interface <port>
    lldp enable
    • Verify LLDP is working:
    show lldp neighbors
    • Delete LLDP:
    • Disable LLDP on a specific interface:
    config
    interface <port>
    no lldp enable
    • Clear LLDP neighbors manually:
    clear lldp neighbors
    • Update LLDP:
    • Change the advertisement interval:
    config
    lldp transmit-interval <seconds>
    • Modify LLDP settings (e.g., system description, port ID):
    config
    lldp system-description "New Description"
    Deepak Pangare
