Wired Intelligent Edge
CX 6200 Real Power Consumption
  • 1.  CX 6200 Real Power Consumption
    Posted 24 days ago
    Hello pals
    I wanna ask you maybe a silly question. It is about CX 6200 PoE version and the available power supplies.
    I need to dimension the power for an implementation in a DC
    The switch is the CX 6200M 48G Class4 PoE 4SFP+ Switch (R8Q70A) with two (02) X372 54VDC 680W 100-240VAC Power Supplies (JL086A). Each power supply will be assigned a circuit.
    Assume that the switch will server in the future the maximun number of PoE devices that the available power budget can serve. No need to consider redundancy scheme.
    If I assign Circuit 1 (C1) to Power Supply 1 (PS1) and C2 to PS2
    What will be the maximun power each PS (or circuit) will consume?
    Regards
