Network Management
  • 1.  CX equivalent for logging notify
    Posted May 30, 2024 08:54 AM
    In AOS-S when a change is made in the running config, a notification can be sent to a syslog server using the "logging notify running-config-change". Is there an equivalent in AOS-CX?
  • 2.  RE: CX equivalent for logging notify
    Posted Jul 26, 2024 02:51 AM
    I'm looking for the same config option.  Did you find it?
    Aaron Wheeler
  • 3.  RE: CX equivalent for logging notify
    Posted Jul 26, 2024 09:50 AM
    I have not found an equivalent. The only solution I came up with was to use the "logging x.x.x.x include-auditable-events" command to send the logs to a syslog server and then build logic on the syslog server to alert when it sees the configuration change. However, this means I am sending all logs to my syslog server and I have to rely on the logic for the alert to be triggered. Not sure how Aruba missed carrying this command over.
  • 4.  RE: CX equivalent for logging notify
    Posted Jul 28, 2024 10:01 PM
    Yeah, strange why this command was not carried over.
    I ended up using SNMP-SERVER TRAP CONFIGURATION-CHANGES and using this trap on my network management server to track configuration changes, but it is not ideal having to create some additional logic for the CX switches.
    Aaron Wheeler
