Comware
  • 1.  CX LAG Connection issue
    Posted Jan 17, 2025 07:09 AM
    I'm in the process of trying to create standard LACP Layer 2 LAG's between some switches, in this case a 6300M (R8292A) and 6405v2. I'm using the 25GB interfaces as follows;
    6300M (Firmware FL.10.13.1060)
    1/1/27
    1/1/28
    6405v2 (Firmware FL.10.13.1060)
    1/4/45
    1/5/45
    The 25Gb links are up on both ports on both switches, reporting the correct speeds with no errors. It's a pretty basic LAG config (no VSX), but the LAG won't come up and reports down.
    The config on the 6300M is;
    interface lag 20
        no shutdown
        no routing
        vlan trunk native 1
        vlan trunk allowed all
        lacp mode active
        hash l2-src-dst
    interface 1/1/27
        no shutdown
        speed 25g
        flow-control rxtx
        lag 20
    interface 1/1/28
        no shutdown
        speed 25g
        flow-control rxtx
        lag 20
    The config on the 6405 is;
    interface lag 20
        no shutdown
        no routing
        vlan trunk native 1
        lacp mode active
        hash l2-src-dst
    interface 1/4/45
        no shutdown
        speed 25g
        flow-control rxtx
        lag 20
    interface 1/5/45
        no shutdown
        speed 25g
        flow-control rxtx
        lag 20
    The LAG will not come up though for some reason I can't see.
    6300M
    System-ID       : 34:c5:15:04:10:00
    System-priority : 65534
    Aggregate lag20 is down
     Admin state is up
     State information : Disabled by LACP or LAG
     Description :
     Type                        : normal
     Lacp Fallback               : Disabled
     MAC Address                 : 34:c5:15:04:10:00
     Aggregated-interfaces       : 1/1/27 1/1/28
     Aggregation-key             : 20
     Aggregate mode              : active
     Hash                        : l2-src-dst
     LACP rate                   : slow
     Speed                       : 0 Mb/s
     Mode                        : trunk
    6405
    System-ID       : 9c:37:08:5f:4e:00
     Admin state is up
     State information : Disabled by aggregation
     Description : rom-cab38-uplink
     Type                        : normal
     MAC Address                 : 9c:37:08:5f:4e:00
     Aggregated-interfaces       : 1/4/45 1/5/45
     Hash                        : l2-src-dst
     LACP rate                   : slow
     Speed                       : 0 Mb/s
     Mode                        : trunk
    I'm happy to provide more info, but this is very strange. I never had a single problem with LACP trunks on the previous generation 5300/2530 switches - they just worked every time. Any help would be massively appreciated.
  • 2.  RE: CX LAG Connection issue
    Posted Jan 17, 2025 08:52 AM
    Ok, I've managed to fix it - sorry for any inconvenience
  • 3.  RE: CX LAG Connection issue
    Posted Feb 03, 2025 08:08 AM
    What did you do to fix it?
  • 4.  RE: CX LAG Connection issue
    Posted Jan 26, 2025 04:17 PM
    Hello, Tony. Hope you're fine.
    Please, use the diagnostics tool to get diagnostic info. Send system log if possible.
    Please, remove all confidential information from inside diagnostic files and send it for us.
    Best regards!
