Some questions / improvement on CX :
VSF stacking led member I don't know if this is only with the 10.08 release, but when you press the button on "Stk", all ports "1" are blinking on the stack so we don't know which switch is number 1/2/3 etc in the stack .. not practical
Still no "show interface description" -> please Aruba could you add this standard command ?
Disable HTTP 80Can we directly disable http port 80 (keep only https for rest API) on the switch without block port 80 on the control-plane ACL ?
Control plane ACL loggingWhy does the control plane ACL doesn't log packet drop ? Again not very practical ..
VSX keepalive :Possibility to use the mgmt port instead of an SFP port like we can do on a VSF stack for split detection?
Thank you !
Laurent from Brest / France
Network Engineer
