Hi Starsky,
You can use the release notes of your desired SW version. Under "Upgrade information" you will find the procedure of how to upgrade the switch SW - the process is the same as with one MM, nothing special.
If you are overriding the active image, which is currently in use (primary/secondary), the process will override the used image by the standby MM and there will be no redundant functionality until the next reboot (reboot will be required to load into the new SW as well).
If you are just downloading the sw to a non active image (primary/secondary), there will be redundancy, but you will still need to boot into the newly downloaded image to finish the update.
Regarding the hitless upgrades - I am not aware of such functionality. If this is implemented, it will be announced in the release notes, or with the new branch SW features.
PS: Don't forget about the "allow-unsafe-updates", if there are any required updates. This step is already mentioned in release notes in the same upgrade section. More info:
https://community.arubanetworks.com/community-home/digestviewer/viewthread?MID=33772------------------------------
Stanislav Naydenov
Original Message:
Sent: Dec 09, 2021 08:10 AM
Subject: CX6400 Dual Management Slots - Software Upgrade
Hi all,
Can anyone point me to a guide which shows how to upgrade a CX 6405 with dual management slots?
I understand that I can't do hitless upgrades (yet), but I still want to document the correct procedure.
Thanks!
