Wired Intelligent Edge
CX6405 - not reachable
  • 1.  CX6405 - not reachable
    Posted Jul 22, 2024 03:20 AM
    facing an issue of one of my CX6405 in a VSX stack not receiving traffic to the switch itself.
    VSX config is done between the two chassis, with an ISL (lag256) and a dedicated keepalived link into a dedicated VRF.
    Each of them has a vlan interface (vlan 252) with an ip address.
    villers01 - 192.168.130.15/24
    villers02 - 192.168.130.16/24
    Default gateway for both is : 0.0.0.0/0 via 192.168.130.1
    In the same VLAN, we have a firewall ( the DG for the switch) with the ip : 192.168.130.1
    From villers02 we can ping the DG
    From villers01 we see that the packet arrives on the firewall, but no answer in the return.
    The two chassis are behind a network managed by the service provider. They are connected to a CISCO Fabric.
    Interface LAG 14 multi-chassis with 2 members :
    - villers01 : 1/4/48
    - villers02 : 1/4/48
    VSX configuration on villers01 :
    vsx
    system-mac 00:00:00:02:02:02
    inter-switch-link lag 256
    role primary
    keepalive peer 192.168.99.2 source 192.168.99.1 vrf KeepAlived
    vsx-sync aaa acl-log-timer bfd-global bgp copp-policy dhcp-relay dhcp-server dns icmp-tcp lldp loop-protect-global mac-lockout mclag-interfaces neighbor ospf qos-global route-map sflow-global snmp ssh stp-global time vsx-global
    ip route 0.0.0.0/0 192.168.130.1
    VSX configuration on villers02:
    vsx
    role secondary
    keepalive peer 192.168.99.1 source 192.168.99.2 vrf KeepAlived
    We have on another site, exactly the same configuration. And we don't have this behaviour.
    Only thinks that i can see is some differences into the routing table on VSX :
    For the functional site :
    herstal01 :
    sw-chassis-her01# show vsx ip route
    IPv4 Forwarding Routes
    '[x/y]' denotes [distance/metric]
    0.0.0.0/0, vrf default
    via 192.168.140.1, [1/0], static on sw-chassis-her01
    via 192.168.140.1, [1/0], static on sw-chassis-her02
    192.168.140.0/24, vrf default
    via vlan1700, [0/0], connected on sw-chassis-her01
    via vlan1700, [0/0], connected on sw-chassis-her02
    192.168.140.173/32, vrf default
    via vlan1700, [0/0], local on sw-chassis-her01
    192.168.140.174/32, vrf default
    via vlan1700, [0/0], local on sw-chassis-her02
    herstal 02 :
    sw-chassis-her02# show vsx ip route
    For the site with the issue :
    villers01 :
    sw-chassis-villers01# show vsx ip route
    via 192.168.130.1, [1/0], static on sw-chassis-villers02
    192.168.130.0/24, vrf default
    via vlan252, [0/0], connected on sw-chassis-villers01
    192.168.130.15/32, vrf default
    via vlan252, [0/0], local on sw-chassis-villers01
    192.168.130.16/32, vrf default
    villers02 :
    sw-chassis-villers02# show vsx ip route
    via 192.168.130.1, [1/0], static on sw-chassis-villers01
    via vlan252, [0/0], connected on sw-chassis-villers02
