Wired Intelligent Edge
  • 1.  CXOS dot1x reject-role
    Posted Jun 08, 2022 05:10 AM
    Edited by flatline Jun 08, 2022 12:07 PM
    G'day all,
    I'm working with a customer setting up Aruba Central and dot1x. All switches are managed by Central. Dot1x works well for clients that should be able to authenticate. However, for wired clients not supporting dot1x, we want them to end up in the guest role, but they are not getting access to the network.
    Here is my role and policy config
    class ip any-any-class
       10 match any any any
    port-access policy guest-policy
       10 class ip any-any-class
    port-access role guest
       associate policy guest-policy
       auth-mode client-mode
       poe-priority low
       trust-mode none
       stp-admin-edge-port
       vlan access 500​
    In addition, the default vlan of a port is 500 and a reject-role of guest is configured on all copper interfaces.
    interface 1/1/1
        no shutdown
        vlan access 500
        spanning-tree bpdu-guard
        spanning-tree root-guard
        spanning-tree port-type admin-edge
        aaa authentication port-access critical-role guest
        aaa authentication port-access preauth-role pre_auth
        aaa authentication port-access reject-role guest
        aaa authentication port-access dot1x authenticator
           max-eapol-requests 1
           max-retries 1
           enable
        loop-protect
        exit
    When a non-dot1x client plugs into the switch, it fails auth as expected, but it never receives the guest role, and whilst it is in vlan 500, it cannot communicate with the outside world and never gets an IP address from DCHP. If I remove dot1x from the port and connect the client, it gets an IP in vlan 500 and all is well.
    Below you see the output from show port-access clients
    Status Codes: d device-mode, c client-mode, m multi-domain
    Port MAC-Address Onboarding Status Role Device Type
    Method
    c 1/1/1 40:b0:aa:aa:aa:aa Fail​
    I can see the mac-address of the client in the mac address table, but no access is available for the client.
    Do you have any idea of what is going on? Why is the reject-role not being assigned as expected? Or is it a case of since dot1x has failed, that the port is completely unavailable to the client? Mind you, that would seem odd as that would prevent such a guest scenario as we are discussing here.
  • 2.  RE: CXOS dot1x reject-role
    Posted Jun 08, 2022 12:07 PM
    The solution to this is to use the command
     port-access fallback-role <role-name>​
    at the interface level. As an example, see below.
    class ip fallback-class
    port-access policy fallback-policy
        10 class ip fallback-class
    interface 1/1/1
        no shutdown
        vlan access 500
        loop-protect
        port-access fallback-role fallback-role
            max-retries 1
            enable
    And the show command to verify things are as they should be
    sw-it-01# show port-access clients
    Port Access Clients
                                 Method
    c 1/1/1    f4:a8:bb:bb:bb:bb                Success     fallback-role, Fallback
    c 1/1/4    28:16:aa:aa:aa:aa dot1x          Success     employee
