Wired Intelligent Edge
  • 1.  DAC cable
    Posted Dec 13, 2023 05:51 AM
    Does someone know the part code for the DAC cable for a 2930M, Iris doesn't seem to list them.
  • 2.  RE: DAC cable
    Posted Dec 13, 2023 08:03 AM
    You could check the 2930M datasheet, near to the end there is a list of compatible transceivers, including DAC. Or check the AOS-Switch/AOS-CX Transceiver Guide.
  • 3.  RE: DAC cable
    Posted Dec 13, 2023 11:09 AM
    Hi Herman, The Datasheet doesn't mention the SFP56 option, will this work in an SFP port, I can't use the other DAC types as I've got a 4-P Smart Rate module in the slot so can't get a SFP+ or an SFP28.
  • 4.  RE: DAC cable
    Posted Dec 14, 2023 04:54 AM
    The transceiver guide lists two 50Gbps SFP56 DAC cables.
    I should say that transceiver/DACs are not my primary area of expertise, and just searched for the information. It may be good to get this validated with your Aruba Partner or local Aruba SE.
  • 5.  RE: DAC cable
    Posted Dec 14, 2023 05:08 AM
    DAC cables are only available with JL078A 40Gig module.
    NHN
