Comware
  • 1.  DAC Cables
    Posted Feb 17, 2019 08:14 PM
    Hi All,
              does anyone know if you can use teh J9283B DAC cables with FF5700 series switches?
    Regards
  • 2.  RE: DAC Cables
    Posted Feb 19, 2019 04:09 AM
    Below are the suported cables on 5700 series.
    HPE FlexFabric 5700 Switch Series accessories
    Transceivers HPE X120 1G SFP LC LH40 1550nm Transceiver (JD062A)
    HPE X120 1G SFP LC BX 10-U Transceiver (JD098B)
    HPE X120 1G SFP LC BX 10-D Transceiver (JD099B)
    HPE X120 1G SFP LC LX Transceiver (JD119B)
    HPE X120 1G SFP RJ45 T Transceiver (JD089B)
    HPE X120 1G SFP LC SX Transceiver (JD118B)
    HPE X125 1G SFP LC LH40 1310nm Transceiver (JD061A)
    HPE X125 1G SFP LC LH70 Transceiver (JD063B)
    HPE X130 10G SFP+ LC SR Transceiver (JD092B)
    HPE X130 10G SFP+ LC LRM Transceiver (JD093B)
    HPE X130 10G SFP+ LC LR Transceiver (JD094B)
    HPE X130 10G SFP+ LC ER 40km Transceiver (JG234A)
    HPE X130 10G SFP+ LC LH80 Tunable Transceiver (JL250A)
    HPE X140 40G QSFP+ MPO SR4 Transceiver (JG325A)
    HPE X140 40G QSFP+ LC BiDi 100m MM Transceiver (JL251A)
    HPE X140 40G QSFP+ LC LR4 SM 10km 1310nm Transceiver (JG661A)
    HPE X140 40G QSFP+ LC LR4L 2km SM Transceiver (JL286A)
    HPE X240 10G SFP+ to SFP+ 0.65m Direct Attach Copper Cable (JD095C)
    HPE X240 10G SFP+ to SFP+ 1.2m Direct Attach Copper Cable (JD096C)
    HPE X240 10G SFP+ to SFP+ 3m Direct Attach Copper Cable (JD097C)
    HPE X240 10G SFP+ to SFP+ 5m Direct Attach Copper Cable (JG081C)
    HPE X240 10G SFP+ SFP+ 7m Direct Attach Copper Cable (JC784C)
    HPE X2A0 10G SFP+ to SFP+ 7m Active Optical Cable (JL290A)
    HPE X2A0 10G SFP+ to SFP+ 10m Active Optical Cable (JL291A)
    HPE X2A0 10G SFP+ to SFP+ 20m Active Optical Cable (JL292A)
    HPE X240 40G QSFP+ to QSFP+ 1m Direct Attach Copper Cable (JG326A)
    HPE X240 40G QSFP+ to QSFP+ 3m Direct Attach Copper Cable (JG327A)
    HPE X240 40G QSFP+ to QSFP+ 5m Direct Attach Copper Cable (JG328A)
    HPE X240 40G QSFP+ to 4x10G SFP+ 1m Direct Attach Copper Splitter Cable (JG329A)
    HPE X240 40G QSFP+ to 4x10G SFP+ 3m Direct Attach Copper Splitter Cable (JG330A)
    HPE X240 40G QSFP+ to 4x10G SFP+ 5m Direct Attach Copper Splitter Cable (JG331A)
    HPE X2A0 40G QSFP+ to QSFP+ 7m Active Optical Cable (JL287A)
    HPE X2A0 40G QSFP+ to QSFP+ 10m Active Optical Cable (JL288A)
    HPE X2A0 40G QSFP+ to QSFP+ 20m Active Optical Cable (JL289A)
    Below are the links for data sheet & quick specs for more support information.
    https://h50146.www5.hpe.com/products/networking/datasheet/HP_5700_Switch_Series_J.pdf
    https://h20195.www2.hpe.com/v2/getdocument.aspx?docname=c04347352
