Comware
  • 1.  DAC Cables
    Posted Feb 17, 2019 08:20 PM
    Hi Folks,
                   does anyone what SFP+ DAC cable that you need to connect a Procurve E5406 and a FF 5700-32XGT-8XG, will J9283B work.
    Regards
  • 2.  RE: DAC Cables
    Posted Feb 19, 2019 06:14 AM
    Below are the only supported cables listed in each switch quick spec guide. Although using any of the below dac cable might work it is recommended to use listed cables & note unsupported cables are not listed.  :)
    (J9283B) 5400 series > HPE X242 10G SFP+ to SFP+ 3m Direct Attach Copper Cable
    (JD097C) 5700 series > HPE X240 10G SFP+ to SFP+ 3m Direct Attach Copper Cable
    5400 quick specs > https://h20195.www2.hpe.com/v2/getdocument.aspx?docname=c04293383
    5700 quick specs> https://h50146.www5.hpe.com/products/networking/datasheet/HP_5700_Switch_Series_J.pdf
