I've got a 2930 runnig 16.8.3 which I use to play with all things clearpass and DUP.
I've A DUP profile that wors just fine for an eap-tls device which gets dropped into a named VLAN called "roaming" This work just fine. ip address out of a pool and DDNS to get FQDN name assigned to it.
I've also got an AP that I wanted to drop into the same VLAN, so I set up some clearpass configs and sent the same DUP.
However this time the switch said
W 06/24/19 16:17:48 05204 dca: ST1-CMDR: Failed to apply user role
UoY_DUP_Roaming___090318-3120-26_7Z4q to macAuth client 204C033A6088
on port 2/13: user role is invalid.
Now couldn't see why it said thast as the same role was working with the dot1 device.
In the end i suspect it was cleasrpas sending a DUR and a "standard" vlan assignment that confiused things as when I removed the "2nd" vlan asignment into a "local_5" vlan ( vlan 5 ,where we usually piut APs) things sprang into life
However, my question is, if on a switch you do see "user role is invalid" and you know the role is o.k. what tools are there on the switch to find out what is going on. Think I fixed this by going "what if... " , I'm sure there must be a more logical way of debugging this
