My X505 was super-loud too. I cracked the case and swapped the fans. It uses standard-sized fans. If I remember correctly, the fan connectors may be different, so either buy fans with the right connectors, or buy some of the standard molex 4-pin power "Y" cables and use that instead. I watch the temps and they look good after the fan swap. Much quieter too.
