Default country in phone selector
  • 1.  Default country in phone selector
    Posted May 08, 2018 04:37 PM
    At registration.php I have an input field where you can select your country. Currently it is set to US, but since 90% of my guests are Danish, I would like to change it to be at Danish as default.
    How is this possible?
    Br,
    Thomas
  • 2.  RE: Default country in phone selector
    Posted May 09, 2018 04:00 AM
    You can set that in the visitor_phone field. If you enter the self-registration flow, enter the form for the registration page, there edit the visitor_phone, you can set preferred countries that show up on the top of the list, and first is the default:Screen Shot 2018-05-09 at 9.56.49 AM.png
    After that, the input will look like:
  • 3.  RE: Default country in phone selector
    Posted May 09, 2018 04:23 AM
    Thank so much :)
