  • 1.  Defining a Role for Captive Portal User
    Posted Jul 18, 2016 01:59 PM
    Wondering if I am missing something.  I have for awhile been leveraging the Server Group to define Capitive Portal Roles after a user has logged on but wondered why the drop down within the Internal DB for Role doesn't function.  Should that work?  Running 6.4.2.15.
         Evan
  • 2.  RE: Defining a Role for Captive Portal User
    Posted Jul 19, 2016 12:07 PM
    The role attribute in the internal database requires a server group with the internal database as the authentication server and a server derivation rule set-up to read the role value:
    This is classed as a server derivation rule and falls in the order documented at the below link:
    http://www.arubanetworks.com/techdocs/ArubaOS_62_Web_Help/Content/ArubaFrameStyles/Firewall_Roles/User_Role_Assignments.htm
  • 3.  RE: Defining a Role for Captive Portal User
    Posted Sep 08, 2016 10:22 AM
    So if I understand this correctly the Internal DB Role Drop Down list is only setting that Attribute Field.  Then I can set a Server Rule to identify the Role Attribute that was selected from the Drop Down List and upon match that will assign the correct User Role Access Control?
  • 4.  RE: Defining a Role for Captive Portal User
    Posted Sep 08, 2016 10:48 AM
    Yes.
