Wired Intelligent Edge
Degraded performance and package duplication with CX 10000 (CX 10k) and private VLAN with Synergy
This thread has been viewed 32 times
  • 1.  Degraded performance and package duplication with CX 10000 (CX 10k) and private VLAN with Synergy
    Posted Jul 31, 2024 11:20 AM
    Hello all,
    does someone already have experience with the setup of a CX 10k with HPE Synergy after deployment like described in https://www.arubanetworks.com/techdocs/AOS-CX/10.09/PDF/HPE_Synergy_and_CX_10000_Networking_Deployment_Guide.pdf ?
    We have the problem of a huge withdraw in bandwidth and the breakage of UDP traffic since we moved all VMware VMs to the private VLAN. Currently the PSM is not active.
    The following symptoms were observed.
    IPERF3-Test
    PVLAN -VM <=> PVLAN-VM => Degraded
    Primary-VLAN <=> PVLAN-VM => 1 Gig/s
    Ping
    PVLAN-VM to PVLAN -VM => Duplicate Answers
    Primary-VLAN <=> PVLAN -VM => Duplicate Answers
    We see a huge number of Jumbo frames.
    copp-policy statistics show a huge number of ip-exceptions.
    Monitoring shows an increasing number of retransmits with more traffic on VMs.
    Several applications using UDP, like Citrix, broke after moving the VM to the PVLAN. Both when accessing from VLAN 100 and from the PVLAN.
    We had to disable duplicate address detection on all Windows devices. (See e.g. https://sps-support.honeywell.com/s/article/False-duplicate-IP-address-detected-on-Windows-devices or https://knowledge.broadcom.com/external/article/344094/automatic-private-ip-addressing-apipa-on.html) We did not disable GARP on the CX10k to avoid any side effects.
    From the taken PCAPs we can see a quite big number of Malformed Packets" and „Unreassembled fragments" which is unusual.
    Does somebody here had the same experience or has any ideas on this?
    Best,
    Adrian
  • 2.  RE: Degraded performance and package duplication with CX 10000 (CX 10k) and private VLAN with Synergy
    Posted Aug 01, 2024 03:04 AM
    Hi, what is the MTU setting on the physical interfaces of the CX switch?
    Regards
    Anders
  • 3.  RE: Degraded performance and package duplication with CX 10000 (CX 10k) and private VLAN with Synergy
    Posted Aug 01, 2024 04:36 AM
    Hi Anders,
    the adapters inside VMware have MTU 1500 configured.
    On the switch we tried both 1500 and 9198 but this didn't make a difference.
    Best,
    Adrian
