Comware
  • 1.  delete files from flash
    Posted Jun 22, 2016 07:11 PM
    Hi
    How can i delete old files from flash mentioned in [filename]. for example here is the output of my core switch
    <CORE-SW>dir /all chassis1#slot5#flash:/
    Directory of chassis1#slot5#flash:/
    5 -rw- 16460 Jun 22 2016 16:25:22 config.cfg
    6 -rw- 7328 Mar 02 2016 18:49:25 config.cwmp
    7 -rw- 7411 Mar 02 2016 18:49:34 system.xml
    8 drw- - Mar 02 2016 18:52:46 logfile
    9 -rw- 36255744 Jun 22 2016 13:52:54 10500-cmw520-r1210p01.bin
    10 -rwh 591 Jun 22 2016 11:32:46 serverkey_v3
    11 -rw- 32920892 Mar 02 2016 18:35:42 [a10500-cmw520-r1126p02.bin] --- How can i delete this file ?
  • 2.  RE: delete files from flash
    Posted Jun 23, 2016 05:33 AM
    Supposing you're on the Active MPU...is the command:
    delete /unreserved flash:/a10500-cmw520-r1126p02.bin
    unable to permanently delete (without involving the system's recycle-bin) the a10500-cmw520-r1126p02.bin file?
    Note (from Documentation):
    The delete /unreserved file-url command deletes a file permanently and the action cannot be undone.
    The delete file-url command moves a file to the recycle bin and the file still occupies storage space. To
    permanently delete the file from the recycle bin execute the reset recycle-bin command in the original
    directory of the file.
    The HPE FlexNetwork 10500 Switch Series provides very good documentation (e.g. Release Notes) about managing its system's files.
