Developer
Demoing Ansible and AOS-CX: Config backups to AWS S3
This thread has been viewed 51 times
  • 1.  Demoing Ansible and AOS-CX: Config backups to AWS S3
    Posted Nov 08, 2020 10:11 PM
    Hello Airheads community
    I want to share an automation demo applied to AOS-CX switches: take network backups and save these backups in a reliable and secure place. With this demo, you can show to customers and prospects automation capabilities of AOS-CX and how much time can be saved by automating repetitive tasks.
    Proposed automation workflow is as follows (Figure 1):
    workflow
    Figure 1
    Workflow steps:
    1. Host Inventory file with management IP addresses of AOS-CX switches.
    2. Playbook file with two tasks:
      2A. Take config backup of AOS-CX switch.
      2B. Synch the backup folder with a bucket in AWS S3.
    3. Run the playbook.
    4. Ansible communicates with the AOS-CX switches that are part of the Host Inventory file, saves the configurations in a local folder and finally synchronizes the folder with a bucket in S3.
    Video of the demo:
    How to setup the demo:
    1. Create a Bucket:
    2. Create an AMI User, Access type set to "programmatic access":
    3. Attach a policy to the AMI User in order to allow access to the S3 bucket:
    4. "aoscx_backup_config" en arubanetworks.aoscx ansible collection:
    https://galaxy.ansible.com/arubanetworks/aoscx
    5. "s3_sync" en community.aws ansible collection:
    https://docs.ansible.com/ansible/latest/collections/community/aws/s3_sync_module.html
    6. Set the ansible_python_interpreter value; Ansible tries to use Python 2 (/usr/bin/python) by default. Details: https://blog.networktocode.com/post/Ansible-Required-Library/
    Code attached.
    Adolfo
    Adolfo Bolivar
    Attachment(s)
    txt
    cx_hosts.txt   591 B 1 version
    txt
    AOS-CX-Backup.txt   680 B 1 version
