What I like to do is get all the AP's on a floorplan (or multiple floorplans). You have to consider the wireless network as a whole before you start turning off individual radios. Generally you keep the radios that are at the edges of the building and consider turning off radios that are more in the middle.
-Put all of your AP's on a floor plan
-Get an idea of how much your AP propagates (how far away from the AP is the signal -65? (assuming the radio is at at least 3/4 power)
-Get a pencil and start assigning 1,6 or 11 to each access point, making sure that AP's on the same channel so not overlap.
-If there is no way to assign a channel to an AP without interfering with another AP, consider turning it off
Once you get your AP channel layout right, same channel AP's will be as far apart as possible. This in turn will cluster clients on the same channel into the same area talking to the same AP (a good thing).
If you go through the effort of mapping your AP's, I would be happy to have a look.
Cheers,
Tobias
