hi all,
i'm back in this thread with more info after paying a visit to the site.
I used the same poe phone with the same eth cable and came out with this discovery.
1) both are same model switches 2530 48poe
2) I ran the command sh int 17 or 31 and no errors display.
However,
When connecting the phone on Sw-1 port 31, the phone had a dial tone busy with a green light status on the device, BUT NO LED STATUS ON THE SWITCH PORT.
When connecting the phone on Sw-2 port 17, the phone tested successfully for voice traffic and the LED STATUS ON THE SWITCH PORT WAS LIT UP.
Both ports are configured the same, also SW-2 where the phone was working, is tot dependent from switch-1. Meaning it is a daisy chain topology network.
FW > connect to SW-1 int 2 > connect to Sw-2 int 1. Both ports are tagged for all traffic.
here's some CLI command below.
WH SW2# sh int 17
Status and Counters - Port Counters for port 17
Name :
MAC Address : 2c59e5-86b76f
Link Status : Up
Port Enabled : Yes
Totals (Since boot or last clear) :
Bytes Rx : 975,173 Bytes Tx : 7,309,055
Unicast Rx : 2,301 Unicast Tx : 2,894
Bcast/Mcast Rx : 129 Bcast/Mcast Tx : 43,734
Errors (Since boot or last clear) :
FCS Rx : 0 Drops Tx : 1
Alignment Rx : 0 Collisions Tx : 0
Runts Rx : 0 Late Colln Tx : 0
Giants Rx : 0 Excessive Colln : 0
Total Rx Errors : 0 Deferred Tx : 0
Others (Since boot or last clear) :
Discard Rx : 0 Out Queue Len : 0
Unknown Protos : 0
Rates (5 minute weighted average) :
Total Rx (bps) : 584 Total Tx (bps) : 4,552
Unicast Rx (Pkts/sec) : 0 Unicast Tx (Pkts/sec) : 0
B/Mcast Rx (Pkts/sec) : 0 B/Mcast Tx (Pkts/sec) : 3
Utilization Rx : 0 % Utilization Tx : 0 %
WH SW2# sh power
brief Show PoE information for the specified slot.
[ethernet] PORT-LIST Show PoE information for the specified ports
<cr>
WH SW2# sh power 17
Status and Configuration Information for port 17
Power Enable : Yes PoE Port Status : Delivering
PLC Class/Type : 1/1 Priority Config : low
DLC Class/Type : 0/- Pre-std Detect : off
Alloc By Config : usage Configured Type :
Alloc By Actual : usage PoE Value Config : n/a
PoE Counter Information
Over Current Cnt : 0 MPS Absent Cnt : 2
Power Denied Cnt : 0 Short Cnt : 0
LLDP Information
PSE Allocated Power Value : 1.0 W PSE TLV Configured : dot3, MED
PD Requested Power Value : 0.0 W PSE TLV Sent Type : dot3
MED LLDP Detect : Disabled PD TLV Sent Type : n/a
Power Information
PSE Voltage : 54.8 V PSE Reserved Power : 1.2 W
PD Amperage Draw : 20 mA PD Power Draw : 1.1 W
Refer to command's help option for field definitions
WH SW1# sh int 31
Status and Counters - Port Counters for port 31
Name :
MAC Address : 445bed-4a96a1
Link Status : Down
Port Enabled : Yes
Bytes Rx : 0 Bytes Tx : 0
Unicast Rx : 0 Unicast Tx : 0
Bcast/Mcast Rx : 0 Bcast/Mcast Tx : 0
FCS Rx : 0 Drops Tx : 0
Unknown Protos : 0
Total Rx (bps) : 0 Total Tx (bps) : 0
B/Mcast Rx (Pkts/sec) : 0 B/Mcast Tx (Pkts/sec) : 0
WH SW1# sh power int 31
Module not present for port or invalid port: int
WH SW1# show power
<cr>
WH SW1# show power 31
Status and Configuration Information for port 31
Over Current Cnt : 0 MPS Absent Cnt : 1
LLDP Information
PSE Allocated Power Value : 3.8 W PSE TLV Configured : dot3, MED
Power Information
PSE Voltage : 55.2 V PSE Reserved Power : 1.1 W
PD Amperage Draw : 19 mA PD Power Draw : 1.1 W
Original Message:
Sent: Feb 21, 2025 02:05 AM
Subject: Desperate help needed in Switch ports poe diagnostics.
This is usually the symptom of failed PoE module that powers port group (assuming the client device is ok and wiring is good). We have many such cases recently. Mostly due to storms. You can check very easily with voltmeter if power is delivered on port. Just google for pin layout for PoE. You should measure >50V DC on port power wires.
You can try with "show tech all" and in some cases you can see PoE failed ports like "Port 194 (channel 1): selftest = FAILED" or something similar.
In almost all cases switch need to be replaced.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2025
Original Message:
Sent: Feb 20, 2025 05:43 PM
Perhaps you can reach out to TAC to see if there is any HW issues.
Original Message:
Sent: Feb 20, 2025 03:32 PM
Have you already checked that the physical cable has the correct nomenclature? that it is not damaged?
by CLI from central you can execute 2 commands in the specific port where you have this problem, the first would be: show interface x/x/x and see that you do not have errors if you have them there is surely a problem in the wiring and the second command would be show power-over-ethernet to see how much is delivering.
Also, do you have LLDP enabled so that they can negotiate correctly the current they need?
The switch is PoE or PoE+, which AP is the one you are connected to, how much power does it need to turn on?
ESAU RUIZ
Original Message:
Sent: Feb 20, 2025 02:40 PM
Hi Ariyap,
the poe used to work and now it doesn't any longer, but it's available to pass data. I was able to test it by connecting my laptop to a specific port.
Is there a way I can just show logs for a specific port?
The command you shared might be to general to narrow down the source.
Thank you,
Original Message:
Sent: Feb 14, 2025 05:59 PM
so does the PoE ports works and then after a while it doesn't? there should be some sort of log generated for it. "show log -r" should provide some indication.
Original Message:
Sent: Feb 14, 2025 11:04 AM
Hi team,
I hope I can get proper help since I wasn't able to get it from the TAC the first time, this is the second time that it's happening after replacing a Switch.
I have 2 Aruba switches 2530 managed in cloud central. Some of the ports are not delivering power to poe devices such as IAP or Voip phones but they do pass data traffic when an end point is connected such as laptop or copier (that don't require power).
In Central, it shows the power being delivered is not even a quarter or the amount that can be handle 300W + and no alerts about ports issues as well. I even tried to change the setting for the designated port as poe "critical" and "high", yet the phone is not getting power.
I tested the phone to another port within the same switch and it's getting power. I'm not so sure whether the building as some power issues that damaged the ports, but this is the second time that I've replaced it.
The first time, when I called the TAC they weren't able to help so they quickly send me a replacement. Now that it happened again, it's imperative that I need to find out
1) If the port is really damaged (burnt/shock).
2) if a notification can be triggered.
3) what it's causing (up to me and facility department if it's an electrical issue).
4) Diagnostc tool (cli commands/power self check) to come conclusion.
Thank you airheads community.
