Cloud Managed Networks
  • 1.  Device Management License
    Posted Jul 12, 2020 08:27 AM
    Does the device manegement license on Aruba Central for IAP support content filter and URL filtering ?
    If content filtering is supported - Do the customer needs to OpenDNS license ?
  • 2.  RE: Device Management License
    Posted Jul 12, 2020 09:43 AM
    Aruba Central (Aruba Instant Solution) doesn't support URL filtering.
  • 3.  RE: Device Management License
    Posted Jul 12, 2020 10:04 AM
    I read in another community post that WebCC is part of Aruba Central device license subscription. Is it not applicable now?
    - Pradyut
    _________________________________________________________________________________________________________________________
    Ce message et ses pieces jointes peuvent contenir des informations confidentielles ou privilegiees et ne doivent donc
    pas etre diffuses, exploites ou copies sans autorisation. Si vous avez recu ce message par erreur, veuillez le signaler
    a l'expediteur et le detruire ainsi que les pieces jointes. Les messages electroniques etant susceptibles d'alteration,
    Orange decline toute responsabilite si ce message a ete altere, deforme ou falsifie. Merci.
    This message and its attachments may contain confidential or privileged information that may be protected by law;
    they should not be distributed, used or copied without authorisation.
    If you have received this email in error, please notify the sender and delete this message and its attachments.
    As emails may be altered, Orange is not liable for messages that have been modified, changed or falsified.
    Thank you.
  • 4.  RE: Device Management License
    Posted Jul 12, 2020 01:23 PM
    Aruba Central only supports Web/Application filtering base on category. not URL Filtering.
    https://community.arubanetworks.com/t5/Controllerless-Networks/Does-the-WebCC-license-still-exist-for-Instant-APs/td-p/531265
  • 5.  RE: Device Management License
    Posted Jul 12, 2020 10:39 PM
    Got it. What about content filtering. Do i required OpenDNS license ?
    - Pradyut
    Thank you.
  • 6.  RE: Device Management License
    Posted Jul 12, 2020 11:32 PM
    WebCC is included with the Central device subscription. No need to purchase separate Webcc if you go with Aruba Central.
