Cloud Managed Networks
/dev/mapper/vg_system-lv_var_log out of space
This thread has been viewed 19 times
  • 1.  /dev/mapper/vg_system-lv_var_log out of space
    Posted Oct 03, 2023 11:32 PM
    Dear Sir,
    Sometimes our Airwave server not function well, we checked from CLI, the root cause is the disk space ( /dev/mapper/vg_system-lv_var_log ) run out of space and we need to execute cleanup to resolve the issue temporary. the df -h information after execute cleanup command :
    Could you please mention me the other solution not only execute cleanup periodically?
    $ df -h
    Filesystem                              Size  Used Avail Use% Mounted on
    devtmpfs                                 48G     0   48G   0% /dev
    tmpfs                                    48G  3.2M   48G   1% /dev/shm
    tmpfs                                    48G   19M   48G   1% /run
    tmpfs                                    48G     0   48G   0% /sys/fs/cgroup
    /dev/mapper/vg_system-lv_root            10G  3.0G  7.1G  30% /
    /dev/sda2                               488M  115M  338M  26% /boot
    /dev/sda3                               256M   12M  245M   5% /boot/efi
    /dev/mapper/vg_system-lv_tmp             10G  787M  9.3G   8% /tmp
    /dev/mapper/vg_system-lv_home           5.0G   33M  5.0G   1% /home
    /dev/mapper/vg_system-lv_var            795G  123G  673G  16% /var
    /dev/mapper/vg_system-lv_var_log         20G   20G  531M  98% /var/log
    /dev/mapper/vg_system-lv_var_log_audit  5.0G   48M  5.0G   1% /var/log/audit
    tmpfs                                    64M     0   64M   0% /var/lib/pgsql/pg_stats_temp
    tmpfs                                   9.5G     0  9.5G   0% /run/user/1001
    tmpfs                                   9.5G     0  9.5G   0% /run/user/995
    tmpfs                                   9.5G     0  9.5G   0% /run/user/0
    tmpfs                                   9.5G     0  9.5G   0% /run/user/994
    Jackson Ku
  • 2.  RE: /dev/mapper/vg_system-lv_var_log out of space
    Posted Oct 06, 2023 04:51 AM
    Best to work with Aruba Support. It can be that some process is in debug mode/state and filling up the disk.
