  • 1.  DFS Channels in dorm rooms?
    Posted Apr 20, 2015 04:03 PM
    Hi:
    I'm planning a high density install in a college dorm building according to the VRF on this topic.
    What are your thoughts on using the DFS channels? Is anyone doing this? What kind of results have you had.
    The 9 available 5Ghz channels are probably enough, but 22 would be even better.
    Tony7
  • 2.  RE: DFS Channels in dorm rooms?
    Posted Apr 20, 2015 04:24 PM
    I have many customers running DFS channels. Device support is very good these days and devices that don't support it will fall back to 2.4.
    Tim
  • 3.  RE: DFS Channels in dorm rooms?
    Posted Apr 21, 2015 02:35 PM
    is there an exhaustive list of devices that shows which channels are supported?
  • 4.  RE: DFS Channels in dorm rooms?
    Posted Apr 21, 2015 06:21 PM
