Wired Intelligent Edge
  • 1.  DHCP config on 6300M
    Posted Jun 11, 2025 06:53 AM
    I have a central Windows DHCP server that I use for 99.9% of our devices, but I have a couple of temperature tracking boxes that do not like some of the default DHCP options that our Windows server provides.  Therefore I would like to set up a local DHCP server on a 6300M switch for use with these devices.
    L3 device is an 8325 switch with a separate VLAN without IP helper for this new VLAN I want to set up
    interface vlan 41
    ip address 10.8.41.254/24
    l3-counters
    This VLAN is allowed on the uplink to the 6300M switch
    L2 device is the 6300M switch
    VLAN is allowed on the uplink to the 8325
    dhcp-server vrf sns
        pool primary-pool
            range 10.8.41.1 10.8.41.10 prefix-len 24
            default-router 10.8.41.254
            dns-server 10.99.1.29 10.254.251.91
            lease 12:00:00
            exit
        authoritative
        enable
    However, the output is as follows where the config status is always showing as Pending.
    FWE-IDF4-232#   sh dhcp-server vrf sns
    VRF Name           : sns
    DHCP Server        : enabled
    Operational State  : operational
    Authoritative Mode : true
    Config_status  : Pending
    Pool Name          : primary-pool
    Lease Duration     : 12:00:00
    DHCP dynamic IP allocation
    Start-IP-Address           End-IP-Address             Prefix-Length
    10.8.41.1                  10.8.41.10                 24
    DHCP Server options
    Note:DHCP Server well known option number mapping:
    default-router(3), Dns-server(6), Domain-name(15),
    Netbios-name-server(44), Netbios-node-type(46)
    Option-Number       Option-Type          Option-Value
     3                  ip                   10.8.41.254
     6                  ip                   10.99.1.29 10.254.251.91
    DHCP Server static IP allocation
    DHCP Server static host is not configured.
    BOOTP Options
    Boot-File-Name            TFTP-Server-Name            TFTP-Server-Address            Next-Server-Address
    Therefore, any idea how I remove the config status as Pending?  Central is not used on this device.
  • 2.  RE: DHCP config on 6300M
    Posted Jun 11, 2025 07:06 AM
    Edited by choppa Jun 11, 2025 08:45 AM
    Hi
    It looks like you don't have an IP interface in VRF sns that can support your DHCP server. So, attach a vlan41 interface to VRF sns on the 6300M and set an IP or move the DHCP server to your 8325 device.
    Thomas
  • 3.  RE: DHCP config on 6300M
    Posted Jun 11, 2025 07:50 AM
    That was it...  I was just missing a local IP address on vlan 41.  Thank you for your help!
  • 4.  RE: DHCP config on 6300M
    Posted Jun 11, 2025 08:18 AM
    No problem. I'd appreciate you marked my post as "best answer".
