If the gateway is on the switch, and the controller is trunked to the VLAN, AND has an ip interface on that VLAN, the controller's dhcp server will assign ip addresses on that VLAN.
I would say that
it is a best practice to have an external DHCP server except for maybe a small guest WLAN. The need for clustering, and/or redundancy will necessitate an external dhcp server. That should be done ahead of time to avoid growing pains in the future. The dhcp scope and reservations on a controller are not synchronized with any other controllers, so if that controller with the dhcp server is disconnected from the network, no new clients will be able to obtain ip addresses. Maintaining multiple dhcp servers on controllers with a split scope is an administrative burden and will make troubleshooting much more difficult.
Original Message:
Sent: Jan 18, 2022 11:08 PM
Subject: DHCP configuration on MC for Wireless SSID on Aruba OS 6.5
Hi Joseph,
Yes, the gateway is on the core switches. However, customer insisted to have the DHCP server on the mobility controller instead. Can it be done?
If the gateway is on core switches and the DHCP server will be on the mobility controller, I will just need to configure ip dhcp helper on the gateway pointing it to the mobility controller's IP interface of the VLAN where the client will reside right?
DarrenPJW
Original Message:
Sent: Jan 18, 2022 05:19 PM
Is the gateway for the client traffic another router?
Does it already have a DHCP server?
Then just bridge the client traffic from the controller to that VLAN and you are all set (either via a trunk or access port from the controller to the layer 3 switch).
Original Message:
Sent: Jan 18, 2022 03:28 PM
Hi Joseph,
If that's the case the IP interface configured in the same VLAN will be used as the gateway for the DHCP subnet? What if the gateway for the VLAN is at other devices, not on the mobility controller?
In addition, can the configuration mentioned works for branch deployment as well?
DarrenPJW
Original Message:
Sent: Jan 18, 2022 02:42 PM
If you give the mobility controller an ip interface in the VLAN you want to supply dhcp to, you would not need to provide a helper address (since the controller can see the broadcasts). You would need to configure a dhcp scope (on the controller) in the same VLAN as the ip interface and make sure dhcp is enabled at the controller.
Original Message:
Sent: Jan 18, 2022 01:15 PM
Hi Joseph,
I'm using the Mobility Controller as DHCP server for the wireless clients connecting using the SSID. Can you point to me how to configure this way?
DarrenPJW
Original Message:
Sent: Jan 18, 2022 12:58 PM
What are you trying to do? If you are supplying DHCP to your clients, your helper address on your VLAN should point to whatever DHCP server you have..
Original Message:
Sent: Jan 18, 2022 11:53 AM
I would like to ask how do we create DHCP for wireless SSID on Mobility Controller? Mobility Controllers currently are on version 6.5.4.
Do we need to configure ip dhcp helper pointing to the mobility controller? Can the configuration works for branch and local deployment?
Thanks in advance
DarrenPJW
