DHCP ip address not allocated
  • 1.  DHCP ip address not allocated
    Posted Aug 01, 2013 11:12 PM
    I have 2 WLANs :
    1)WLAN naik_open_vlan_10 with VLAN 10 Employee VLAN
    2)WLAN naik_open_all_vlan VLAN 1 MgmtVLAN
    My 1) does not work i.e. when user with mac address 7c:11:be:6d:a0:56 tries to associate it does not get DHCP allocated ip address.
    My 2) works fine though .
    DHCP server is external Win2008
    Please see logs below :
    Attachment(s)
    txt
    mc1_log.txt   8 KB 1 version
  • 2.  RE: DHCP ip address not allocated
    Posted Aug 01, 2013 11:16 PM
    Where are your VLAN interfaces? In the controller or upstream?
    Sent from my BlackBerry Z10
  • 3.  RE: DHCP ip address not allocated
    Posted Aug 01, 2013 11:45 PM
    Why is VLAN 10 and 1 handing out IPs on the same scope ?
    Controller Log ,Good Example ,(WLAN naik_open_all_vlan VLAN 1 MgmtVLAN )
    MAC=7c:11:be:6d:a0:56,IP=10.254.1.106
    Controller Log ,Bad Example (WLAN naik_open_vlan_10 with VLAN 10 Employee VLAN)
    Aug 1 19:46:01 :522050:  <INFO> |authmgr|  MAC=7c:11:be:6d:a0:56,IP=10.254.1.106
    Can you do a show arp | include <devicemac> on the controller ?
    And you please confirm the DHCP configuration
    Also do a show trunk and show vlan on the controller to make sure the VLAN is active and up/up and do the same on the interface of the upstream switch
  • 4.  RE: DHCP ip address not allocated
    Posted Aug 01, 2013 11:57 PM
    (MC1) (config) #show arp Protocol Address Hardware Address Interface
    Internet 10.254.1.101 00:1A:1E:C0:BD:E6 vlan1
    Internet 10.254.1.1 00:0B:86:63:BA:10 vlan1
    Internet 10.254.1.103 00:0B:86:66:BD:3E vlan1
    Confirm what on DHCP configuration ?
     Also checked the trunk
    (MC1) # show trunk
    Trunk Port Table
    Port Vlans Allowed Vlans Active Native Vlan
    FE1/4 ALL 1,10-11 1
    (MC1) #show interface fastethernet 1/4 switchport   -> to Switch
    Switchport: Enabled
    Administrative mode: trunk
    Operational mode: trunk
    Administrative Trunking Encapsulation: dot1q
    Operational Trunking Encapsulation: dot1q
    Access Mode VLAN: 0 ((Inactive))
    Trunking Native Mode VLAN: 1 (Default)
    Trunking Vlans Enabled: ALL
    Trunking Vlans Active: 1,10-11
  • 5.  RE: DHCP ip address not allocated
    Posted Aug 02, 2013 12:06 AM
    Below are Switch confguration
    (Switch_Naik) (config) #show interface fastethernet 1/7 switchport -> to DHCP Server
    Switchport: Enabled
    (Switch_Naik) (config) #show interface fastethernet 1/4 switchport ->To MC1
    Switchport: Enabled
  • 6.  RE: DHCP ip address not allocated
    Posted Aug 02, 2013 12:12 AM
    VLAN interfaces are  on the switch with ip address set
    (Switch_Naik) (config) #show ip interface brief
    Interface IP Address / IP Netmask Admin Protocol
    vlan 1 10.254.1.1 / 255.255.255.0 up up
    vlan 10 10.254.10.1 / 255.255.255.0 up up
    vlan 11 10.254.11.1 / 255.255.255.0 up up
    loopback unassigned / unassigned up up
    mgmt unassigned / unassigned down down
    (Switch_Naik) (config) #show vlan
    VLAN CONFIGURATION
    VLAN Description Ports AAA Profile
    1 Default FE1/0-5 FE1/7 GE1/8 Pc0-7 N/A
    10 VLAN0010 FE1/4-5 FE1/7 N/A
    11 VLAN0011 FE1/4-5 FE1/7 N/A
  • 7.  RE: DHCP ip address not allocated
    Posted Aug 02, 2013 12:18 AM
    To clarify, please run the requested commands from the MC, not the switch.
    What VLAN is the DHCP server on?   Do you have anything setup to forward DHCP requests for VLAN 10 to this IP?  Either on the controller or the switch?
  • 8.  RE: DHCP ip address not allocated
    Posted Aug 02, 2013 12:26 AM
    (Switch_Naik) (config-subif)#show interface vlan 10
    VLAN10 is up line protocol is up
    Hardware is CPU Interface, Interface address is 00:0B:86:63:BA:10 (bia 00:0B:86:63:BA:10)
    Description: 802.1Q VLAN
    Internet address is 10.254.10.1 255.255.255.0
    Routing interface is enable, Forwarding mode is enable
    Directed broadcast is disabled, BCMC Optimization disabled ProxyARP enable Suppress ARP enable
    Proxy Arp is enabled for the Interface
    IP Helper Addresses Configured on this Interface:
    10.254.1.21
    VLAN 10 has ip helper configured as seen above .
    DHCP Server is trunk connected to Swicth as seen in out put in this thread (
    show interface fastethernet 1/7 switchport)
  • 9.  RE: DHCP ip address not allocated
    Posted Aug 02, 2013 12:11 AM
    to understand this better, can you share the following with us:
    show vlan
    show trunk you have already shown this
    full results on both networks of the following:
    logging level debug networking subcat dhcp
    Attempt to connect to First Network
    show log network | include <MAC>
    Attempt to connec tot Second Network
    After:
    no logging level debug networking subcat dhcp
  • 10.  RE: DHCP ip address not allocated
    Posted Aug 02, 2013 12:23 AM
    Please see attached file
    Attachment(s)
    txt
    info2.txt   2 KB 1 version
  • 11.  RE: DHCP ip address not allocated
    Posted Aug 02, 2013 12:38 AM
    Thank you for the logs.   The only other question I have at the moment is on the switchport to the DHCP server, you have it configured for trunking.  Do you have the Server NIC setup that way too?   Based on the IP, the DHCP server is on VLAN 1; then you should just setup that port as an access port and let the ip helper address for the VLAN route the request to the server.   Lastly, have you confirmed that DHCP scope can give out addresses to wired devices?
  • 12.  RE: DHCP ip address not allocated
    Posted Aug 02, 2013 03:15 AM
     it is a windows machine and does not allow me to setp the vlan .
     i tried changing from trunk to access , does not help
     yes , it did give to my laptop that i connected from access port with vlan 1 on the port .
    it is other vlans (other  than vlan 1 ) that seem to have issue
  • 13.  RE: DHCP ip address not allocated
    Posted Aug 02, 2013 08:45 AM
    The switchport going to your DHCP server should definitely be an access port / untagged. Also, is the switchport trusted or are you using role-based access control with an untrusted port?
