Wired Intelligent Edge
  • 1.  DHCP IP Helper
    Posted Jun 13, 2023 09:20 AM
    Edited by akmalk14 Jun 13, 2023 09:21 AM
    Hi
      i have 10 different vlans config in 6300m switch and windows dhcp server config with all ip scope . assigned 10.10.2.3 ip to dhcp server and config this to all vlan interface . server ping from switch and server to switch also pinging  .
    but vlans not getting ip from dhcp server what is the issue
    if i miss any config please suggest me
    Core-Switch-Noble(config)# sh ip helper-address
     IP Helper Addresses
     Interface: vlan12
      IP Helper Address                   VRF
      10.10.2.3                           default
     Interface: vlan13
      10.10.2.3                           default
     Interface: vlan14
      10.10.2.3                           default
     Interface: vlan15
      10.10.2.3                           default
     Interface: vlan16
      10.10.2.3                           default
     Interface: vlan17
      10.10.2.3                           default
     Interface: vlan18
      10.10.2.3                           default
     Interface: vlan19
      10.10.2.3                           default
     Interface: vlan20
      10.10.2.3                           default
  • 2.  RE: DHCP IP Helper
    Posted Jun 14, 2023 01:07 AM
    Can the VLANS ping the server?
  • 3.  RE: DHCP IP Helper
    Posted Jun 14, 2023 03:50 AM
    Edited by akmalk14 Jun 14, 2023 03:51 AM
    Yes VLAN Ping the server
  • 4.  RE: DHCP IP Helper
    Posted Jun 14, 2023 03:58 AM
    Yes VLAN ping the server
    but now we deicide to config dhcp server on 6300m
    config done but issue vlan use is not accessing internet NIC show internet access but when we browse nothin open
    VRF Name           : default
    DHCP Server        : enabled
    Operational State  : operational
    Authoritative Mode : true
    Config_status  : Pending
    Pool Name          : VLAN12-DESKTOP
    Lease Duration     : infinite
    DHCP dynamic IP allocation
    Start-IP-Address           End-IP-Address             Prefix-Length
    10.10.4.2                  10.10.5.254                23
    DHCP Server options
    Note:DHCP Server well known option number mapping:
    default-router(3), Dns-server(6), Domain-name(15),
    Netbios-name-server(44), Netbios-node-type(46)
    Option-Number       Option-Type          Option-Value
     3                  ip                   10.10.4.1
    DHCP Server static IP allocation
    DHCP Server static host is not configured.
    BOOTP Options
    Boot-File-Name            TFTP-Server-Name            TFTP-Server-Address            Next-Server-Address
    Pool Name          : VLAN13-Wifi-AP
    10.10.6.2                  10.10.7.254                23
    DHCP Server options
     3                  ip                   10.10.6.1
    BOOTP Options
    Pool Name          : VLAN14-Biometric
  • 5.  RE: DHCP IP Helper
    Posted Jun 14, 2023 04:05 AM
    You need to input DNS on the pool.
  • 6.  RE: DHCP IP Helper
    Posted Jun 14, 2023 04:22 AM
    now its working . Thanks
  • 7.  RE: DHCP IP Helper
    Posted Jun 14, 2023 04:16 AM
    you can use dhcp-relay
    first enable dhcp-relay globally, then configure IP helper-address on the interface
    #show dhcp-relay
    https://www.arubanetworks.com/techdocs/AOS-CX/10.07/HTML/5200-7837/Content/Chp_DHCP/DHCPv4_relay_cmds/ip-hel-add-10.htm
    NHN
