  • 1.  DHCP not Working with WPA-Personal AES SSID
    Posted Mar 11, 2022 04:54 PM
    I have a strange problem that I have not been able to figure out. I hope someone here can solve it for me or direct me in the right direction.
    The Environment:
    Cluster of 27 IAP 103s (Soon to become 515s)
    Virtual Controller version: 6.5.4.21
    Current Configuration uploaded as a text document.
    Juniper EX3400's Switches
    The Problem:
    I have three SSIDs that us WPA-PERSONAL AES. When you look at the attached configuration file, the two I'm having problems with are my SFTemp and SFSD-M SSIDs. The display-network SSID is not having the problem I'm about to explain.
    The problem  is the two SSIDs mentioned above will just stop handing out IP addresses to clients. Sometimes switching to the Guest network than back to the secure ones fixes this problem and other times it clears up in a minute or two. The problem also effects anyone at random and it can be any type of device, iPads, Chromebooks, windows devices.
    Checking the switches and the DHCP server shows there is more than enough IP addresses for either of these networks. The switches don't report any problems either. Ran a Tech Support dump on the cluster and I personally don't see anything that looks like an obvious problem.
    Troubleshooting Steps Taken So Far:
    Updated the APs
    Updated the end points drivers. This was done when the problem first showed up. I thought it was a problem with the computer not the network.
    Restarted the cluster
    Upgraded AP to IAP 515's
    I pulled an AP from a location reporting the problem yesterday and I am currently working on replicating the problem, but since it's not consistent, it's been a pain to narrow it down.
    Please let me know if any other supporting files could help in this process. I really hoped upgrading tot eh 515's would solve this problem, but it did not.
    I also attached the support dump from one of the AP's in the cluster that was having problems yesterday.
    -Thanks
    Ty Bower
    Network/System Analyst | CEH
    Attachment(s)
    txt
    backup.txt   5 KB 1 version
    txt
    support-dump.txt   605 KB 1 version
  • 2.  RE: DHCP not Working with WPA-Personal AES SSID
    Posted Mar 11, 2022 05:45 PM
    Is the VLAN for the guest SSID network-based or Virtual Controller based?
  • 3.  RE: DHCP not Working with WPA-Personal AES SSID
    Posted Mar 11, 2022 05:49 PM
    Sorry,
    All the different SSID's are on their own VLAN.
    Ty Bower
  • 4.  RE: DHCP not Working with WPA-Personal AES SSID
    Posted Mar 11, 2022 09:04 PM
    You should ensure that the guest VLAN is trunked to all of your APs.​
