We are using a 4500G as our Layer 3 switch and as a DHCP relay agent sending all DHCP requests to our Netware DHCP server. Everything works fine for a couple days, but after a while clients can no longer get ip addresses.
The solution is to undo and then redo the DHCP SELECT RELAY command. As soon as I do this on a given interface, everything works again for that VLAN.
It appears this has something to do with the 4500G keeping old entries in its ARP table, i.e. when the problem occurs there are usually multiple ip addresses listed for the same client MAC address.
Running the latest firmware on the switch.
Does anyone have any idea what is going on here?
