Wired Intelligent Edge
  • 1.  dhcp relay on 6100 switch
    Posted Mar 15, 2021 06:53 PM
    Edited by damima Mar 15, 2021 06:54 PM
    is there any way that DHCP relay can be turned on on 6100? To bad Aruba actually do not support this or I am missing something here.
    damima
  • 2.  RE: dhcp relay on 6100 switch
    Posted Mar 15, 2021 08:33 PM
    The 6100 are entry level access switches. They can act as a DHCP client, but do not offer any other DHCP features like DHCP Server or DHCP Forwarding.
    Dustin Burns
  • 3.  RE: dhcp relay on 6100 switch
    Posted Mar 16, 2021 02:34 AM
    Thanks. I figured out that. But I have assumed this since it can do some L3 routing. Aruba should have it as pure L2 switch.
    ________
    damima
  • 4.  RE: dhcp relay on 6100 switch
    Posted Sep 14, 2022 08:41 AM
    As of CX 10.10, this is no longer the case and DHCP relay is supported on the 6000 and 6100 series.
    as per the configuration guide
    https://www.arubanetworks.com/techdocs/AOS-CX/10.10/PDF/cli_6000-6100.pdf
  • 5.  RE: dhcp relay on 6100 switch
    Posted Sep 15, 2022 04:16 AM
    There is a great resource for checking what is supported on ArubaOS-CX switches on what FW version.
    AOS-CX Feature Navigator
    Best, Gorazd
