Hey everybody.
This is probably an easy fix for, but I am in the process of enabling dhcp snooping on the switches at a customer.
The network is designed with a fortigate in front, which is the dhcp server in each vlan, and one "core" switch connected to the fortigate, and the other switches connected to the core switch.
The question I have is if I am gonna use the command dhcpv4-snooping authorized server x.x.x.x in the config state, which ip from the fortigate should I use?
Lets say the fortigate is dhcp for these 3 subnets (10.1.1.0, 10.1.2.0, 10.1.3.0) and the fortigate has an ip address in each of those subnets.
should i then authorize all of the ip? or is it enough with one of them?
Regards.
