Wired Intelligent Edge
  • 1.  DHCP SNOOPING mit DHCP Relay
    Posted Nov 21, 2016 10:28 AM
    Szenario:
    DHCP Relays on the router in the Core-Network for multiple VLANs and I want to use DHCP-Snooping at the Access-Layer with the ArubaOS-Switch 2530-Series. (DHCP-Server is running on VM)
    For DHCP-Snooping i have to configure "dhcp-snooping authorized-server". For example the DHCP-Server.
    Did i have to set the interface-adresses from the VLANs with DHCP-Relays as "dhcp-snooping authorized-server" ,too?
    Cause i mean DHCP-Snooping acts at Layer 2.
    Thanks 4 answers.
    #DHCP
  • 2.  RE: DHCP SNOOPING mit DHCP Relay
    Posted Nov 21, 2016 08:25 PM
    I had Procurve edge switches and a 3COM core - I had to add in the 3COM cores as authorised DHCP servers.
  • 3.  RE: DHCP SNOOPING mit DHCP Relay
    Posted Nov 22, 2016 03:38 AM
    The Core is a 3COM, too. So i have to add all vlan interfaces from the core?
    Would be great if you  could add the DHCP-Servers only... :/
  • 4.  RE: DHCP SNOOPING mit DHCP Relay
    Posted Nov 22, 2016 06:51 PM
    A 3COM core switch *is* a DHCP server.
    Unlike other vendors, it doesn't just proxy the DHCP requests through, it actually acts as a DHCP server itself.
    You shouldn't have too much work to do - your Access switches only need the VLAN interfaces for their local Data and Voice VLANs - should only be two there to do, right?
  • 5.  RE: DHCP SNOOPING mit DHCP Relay
    Posted Nov 23, 2016 02:57 AM
    There will be some more Interfaces to add, cause we use 802.1x with RADIUS to set the VLAN on the access port.
    The work isnt a problem. I just want to understand the configuration :)
    Thanks 4 your reply.
