Comware
  • 1.  DHCP SNOOPING on OfficeConnect Switch 1920S JL385A
    Posted Aug 22, 2019 11:49 AM
    Hi all,
    Is there any way to activate dhcp snooping on HPE OfficeConnect Switch 1920S 24G 2SFP PoE+ (370W) JL385A??  is there any alternative to it?
    I've been trying to implement it on web or cli with no avail?
    Thanks a lot!
  • 2.  RE: DHCP SNOOPING on OfficeConnect Switch 1920S JL385A
    Posted Aug 29, 2019 04:06 AM
    Kindly check under web --.> Network > DHCP and if its not not availble then it might be software/hardware limitations.
    Thanks!
  • 3.  RE: DHCP SNOOPING on OfficeConnect Switch 1920S JL385A
    Posted Mar 05, 2020 09:18 AM
    be the basic functions implemented in the future?
