Aruba Apps
  • 1.  Difference between iap 515 and 565
    Posted Oct 20, 2022 07:32 AM
    Hi team,
    What is the advantage of having IAP 565 over 515.
    What is the signal strength of 565 if we compare it with iap 515.
  • 2.  RE: Difference between iap 515 and 565
    Posted Oct 20, 2022 08:03 AM
    The 565 is an outdoor AP and should not be compared with an indoor AP like a 515.
    Typically the difference between APs with lower numbers and higher numbers is radios, technology and performance in general.
    Start on the page here:  https://www.arubanetworks.com/products/wireless/access-points/indoor-access-points/
  • 3.  RE: Difference between iap 515 and 565
    Posted Oct 20, 2022 08:12 AM
    Hi ,
    What is the range if we connect 565 in open environment.
    Thanks & Regards,
    Shivam Ojha
    Orbit Techsol (W) PVT LTD
    Mob:7743901736 Email: shivam.ojha@orbitindia.net
  • 4.  RE: Difference between iap 515 and 565
    Posted Oct 20, 2022 10:47 AM
    It depends on the height that the access point is mounted as well as the capability of the clients that will be connecting.
