I would expect that the same command but with a vlan (or interface, or something else) would filter the output to a specific vlan, and what you see in the full output should match what you see in the filtered output. From what I understand, after disable/enable, you can't reproduce the issue? If you find how to reproduce, please open a TAC case so they can investigate further and file a bug for this.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Jan 12, 2025 04:45 AM
Subject: Difference between "ip igmp snoop" and "ip igmp snoop vlan 204"?!?
Hello all,
Got call yesterday that clien had issues with multicast streams (PTP and protocol specific streams...) and I noted weird differene while checkin igmp snooping status with "show ip igmp..." commands
Can somebody clarify what is the data difference between "show ip igmp snooping" and "show ip igmp snooping vlan 204"? (See my results from problem vlan below... L2 interface enables igmp snooping with version 2. No static subscriptions nor VSI in this device and querier in vsx core having active-gateway)
There is mention in cli manual that "sh ip igmp snooping vlan..." is about operational data so any ideas why "sh ip igmp snooping" shows group subscriptions but other command not?
(Just noted that if I disable igmp snoopig and put it back on, I'll get same information with both commands... Wondering did I found bug from 10.13.1040?)
SWITCH-111# sh ip igmp snooping vlan 204
IGMP Snooping Protocol Info
Total VLANs with IGMP enabled : 30
Current count of multicast groups joined : 0
IGMP Drop Unknown Multicast : VLAN
VLAN ID : 204
VLAN Name : SoundFIN-EXP
IGMP Configured Version : 2
IGMP Operating Version : 2
Querier Address :
Querier Port :
Querier UpTime :
Querier Expiration Time :
Current count of multicast groups joined : 1
<snip other entries away....>
VLAN ID : 204
Querier Address : 10.130.212.1
Querier Port : lag1
Querier UpTime :0m 37s
Querier Expiration Time :0m 23s
Active Group Address Tracking Vers Mode Uptime Expires
224.0.1.129 Filter 2 0m 36s 0m 24s
Jori Luoto
AV-IT Specialist
