Cloud Managed Networks
Different AP equipment firmware version
  • 1.  Different AP equipment firmware version
    Posted Nov 01, 2021 08:54 PM
    Good Morning
    I have two different Access Point, 1. aruba IAP 207 RW 2. aruba IAP 535 RW, Aruba 207 is the master and have firmware version 8.3.0.5 and Aruba 535 have firmware version 8.7.X.X, when i try to update firmware, it display a message that say: "Image Check Encountered unknown error", i need help but i dont know what to do, i have others AP 305 RW, i see too the certificate is over.
    I want to know what to do, help me.
    Wilmer Ramos
  • 2.  RE: Different AP equipment firmware version
    Posted Nov 04, 2021 05:27 AM
    The existing firmware may be too old and not have the correct certificates to check for updates.
    The easiest way to get out is to get factory images for the version you want to deploy -HERE- and after that, the firmware update check should work again.
    If you have an active support contract on all of the APs, you also can select a specific firmware version from ASP (Aruba Support Portal).
