You are referring to Policy Based Routing. 8360 and 8100 do support PBR but you will have to configure it.
https://arubanetworking.hpe.com/techdocs/AOS-CX/AOSCX-CLI-Bank/cli_8360/Content/Chp_PBR/PBR_cmds/pol-pbr.htm
Shpat | ACEP | ACMP | ACCP | ACDP
Just an Aruba enthusiast and contributor by cases
If you find my comment helpful, KUDOS are appreciated.
Original Message:
Sent: May 23, 2025 06:52 PM
Subject: Different routing depending on source address
We moved our L2 switching to Aruba CX and we are planning to move our edge router to a CX 8100 or 8360.
I am currently trying to see if it can replace our current setup and has all the feature required.
There is one thing I am not sure how to do:
The router has a static routing table for default route on WAN and multiple routes for our internal network LAN (our topology is simple, we have one subnet per vlan).
All vlan uses the same routing, except one.
How can I configure that one vlan in particular has another next hop than the other ones? Also, in addition to a whole vlan, I have a single host that I also want to direct to another router. (that particular host is on a vlan that should be using default routes, only that host should use different route).
