  • 1.  Disable 2.4 Ghz radio
    Posted Mar 07, 2024 09:33 PM
    Hi
    Kindly guide me  for the following
     1.  How to disable 2.4 GHz radio in an SSID
     2.  How to disable 2.4 GHz radio in a particular AP of the cluster
    Dr.Samir Srivastava
    KNIT Sultanpur (UP)
    INDIA
  • 2.  RE: Disable 2.4 Ghz radio
    Posted Mar 08, 2024 02:20 AM
    Edited by mkk Mar 08, 2024 02:20 AM
    What kind of Aruba environment do you have? controller-based setup? AOS8 or AOS10?
    Marcel Koedijk | MVP Expert 2023 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 3.  RE: Disable 2.4 Ghz radio
    Posted Mar 08, 2024 11:46 AM
    HI mkk
    I am using virtual controller. My cluster consists of 61 aruba IAP 515
    Dr.Samir Srivastava
    Associate Professor & Ex - Head
    Computer Sc. & Engg. Deptt.
    KNIT.,Sultanpur(U.P)
    INDIA
    Mobile:09415077351  &  7007474344
  • 4.  RE: Disable 2.4 Ghz radio
    Posted Mar 08, 2024 08:55 AM
    Edited by schmelzle Mar 08, 2024 08:55 AM
    Since this was posted in the Instant discussion. You can do this per SSID in the network configuration. Change the band from All to 5 GHz.
    To turn off the radio entirely for an AP in the cluster, log in to the VC, go to Configuration > Access Points > Select and Edit the target AP > Radio > Turn the respective radio (this may vary depending on the AP model) from Access to Monitor.
  • 5.  RE: Disable 2.4 Ghz radio
    Posted Mar 08, 2024 11:48 AM
    Hi schmeizie
    Thanks for reply
    Dr.Samir Srivastava
    INDIA
