The EEE does seem to be enabled as the client devices have it enabled and it is causing packet loss and network drops on client PC's.
Original Message:
Sent: Jun 08, 2025 11:16 PM
Subject: Disable Energy Efficient Ethernet/Green Ethernet for entire site
I have tried in Central Multi Edit.
no energy-efficient-ethernet but it put it on second line in global. Which is what I want.
However, it complains that it can't sync because some reason.
6300,6200 on 10.15.1020
Any other ideas?
Original Message:
Sent: Feb 24, 2025 03:13 AM
Original Message:
Sent: Feb 24, 2025 02:08 AM
well you can use the "no energy-efficient-ethernet" command for the interface range. something like
int 1/1/1-1/1/24
and you can check if it enabled with this
# sh interface 1/1/1 | incl Energy
Energy-Efficient Ethernet is disabled
Original Message:
Sent: Feb 24, 2025 01:42 AM
Ah ok. Is there any way make sure all ports on site have EEE disabled?
Original Message:
Sent: Feb 20, 2025 05:59 PM
EEE is not enabled by default on CX switches, you can disable it simply from the interface
int 1/1/1
Original Message:
Sent: Feb 20, 2025 03:29 AM
What brand/type/model switch do you have?
How is it configured/managed?
Original Message:
Sent: Feb 19, 2025 11:37 PM
Hi All,
Just wondering how I could disable Energy Efficient Ethernet on all ports on site.
It is causing so much frustrations and lots of tickets.
