Cloud Managed Networks
  • 1.  Disable Energy Efficient Ethernet/Green Ethernet for entire site
    Posted Feb 20, 2025 03:29 AM
    Hi All,
    Just wondering how I could disable Energy Efficient Ethernet on all ports on site.
    It is causing so much frustrations and lots of tickets.
  • 2.  RE: Disable Energy Efficient Ethernet/Green Ethernet for entire site
    Posted Feb 20, 2025 03:30 AM
    What brand/type/model switch do you have?
    How is it configured/managed?
  • 3.  RE: Disable Energy Efficient Ethernet/Green Ethernet for entire site
    Posted Feb 20, 2025 05:59 PM
    EEE is not enabled by default on CX switches, you can disable it simply from the interface
    int 1/1/1
    no energy-efficient-ethernet
  • 4.  RE: Disable Energy Efficient Ethernet/Green Ethernet for entire site
    Posted Feb 24, 2025 01:43 AM
    Ah ok. Is there any way make sure all ports on site have EEE disabled?
  • 5.  RE: Disable Energy Efficient Ethernet/Green Ethernet for entire site
    Posted Feb 24, 2025 02:08 AM
    well you can use the "no energy-efficient-ethernet" command for the interface range. something like
    int 1/1/1-1/1/24
    and you can check if it enabled with this
    # sh interface 1/1/1 | incl Energy
     Energy-Efficient Ethernet is disabled
  • 6.  RE: Disable Energy Efficient Ethernet/Green Ethernet for entire site
    Posted Feb 24, 2025 03:14 AM
