Become a Member
Aruba OS 6.4, Controller 7030 and AP's 205, 215..
I know that is several ways to shut AP's ( in a VAP, Poe shutdown, create an AP group with Radios OFF) but is there anyway to shut just one AP ?
Regards
Create a radio profile on the a band and the g band that has radios off. Apply it to an AP specific profile:
config t ap-name "Kitchen-225" dot11a-radio-profile "shutdown" dot11g-radio-profile "shutdown"
Hi cjoseph
I see this
config trf dot11a-radio-profile testno radio enableexitrf dot11g-radio-profile testno radio enableexitap-group no-radiodot11a-radio-profile testdot11g-radio-profile test
Can I create that profile under webgui?
regards
Go to Configuration> Wireless> AP Configuration> AP Specific. Select your AP, Click on your AP, Expand Wireless LAN> Click on 802.11a radio and create a NEW Radio Profile with the radios off...
Delete the AP-specific configuration to remove the specific config and allow the ap-group configuration to take over.
What is the 8.x way to do this? I want to temporarily shutdown the radios of a specific AP, without moving AP groups, etc.
AP-specific is only available on the commandline in 8.x
cd /md/<path to your config>
config t
ap-name <name of ap>
dot11a-radio-profile rp-scan-a
