Wired Intelligent Edge
  • 1.  Distributed Trunking
    Posted Jun 10, 2014 05:26 AM
    When using server-to-switch distributed trunking, what NIC settings do you set on the server side?
    Is there a specific teaming mode that should be used?
  • 2.  RE: Distributed Trunking
    Posted Jun 10, 2014 11:21 AM
    Hi Brad,
    It all depends on what teaming software you are using on your servers and which version of Windows you are using - if you are using windows.
    dt-trunk would work with SLB on the teaming software.
    dt-lacp would work with LACP on teh teaming software.
    HTH
