  • 1.  Ditching Central for local VC management
    Posted Dec 17, 2019 05:11 PM
    Hi all, we have a IAP deployment managed by a Central demo account that is about to expire. Currently we are not in position of getting a paid suscription so we need to opt out of Central and use local VC management.
    Do you know if there is an established procedure for doing this?
    We were thinking about just disassociating all of the serial numbers from Central, but I don´t know if this will just work this way, I haven´t done it before.
    Thanks in advance.
  • 2.  RE: Ditching Central for local VC management
    Posted Dec 17, 2019 10:08 PM
    all you have to do is exactly that, and the instant cluster will retain their last known config.
  • 3.  RE: Ditching Central for local VC management
    Posted Dec 17, 2019 10:59 PM
    After disconnecting from Aruba Cetral Editable configuration option will be available in Instant Dashboard. We have tested this in our Labs. Now you should able access local dashboard with read-only permissions. isn't it.
  • 4.  RE: Ditching Central for local VC management
    Posted Dec 18, 2019 09:21 AM
    Yes, that's correcto, currently local management is read only. I expecto to make these changes within this week, thank you for your replies.
  • 5.  RE: Ditching Central for local VC management
    Posted Dec 18, 2019 06:09 PM
    Than you for your comments, everything went as expected.
