  • 1.  Docxument detailing cppm syslog Data/Format
    Posted Feb 19, 2024 11:10 AM
    CPPM 6.11.7 - currently sending syslog data to a splunk setup .. problem is they dont want all of it ( trimmed down to auth and acounting)  and alo want  some details regarding whats in the syslog data. Just to save me time writing something, is there a cppm doc  that covers all this ?
    A
  • 2.  RE: Docxument detailing cppm syslog Data/Format
    Posted Feb 20, 2024 04:21 AM
    I'm not sure if I ever saw something like that, however if you configure RFC 5424 or CEF, there are field names in the logs that pretty much describe what is in the log file.
    Also, you configure yourself what fields are in the syslog message, so there is not really a standard log. Your SIEM vendor probably has guidance what data needs to be in the log messages to fully support your use-case.
  • 3.  RE: Docxument detailing cppm syslog Data/Format
    Posted Feb 20, 2024 05:03 AM
    Hi
    Sort of what I expected. Just looking to Dave myself some time documenting stuff. We’re sending data to a splunk team who want to know what’s they’re looking at in the syslog data … yes we’re using CEF.
    Ok I'll put something together
    Thx
    A
