I suspect that the only difference is that new Campus-Cable are ready and compatible ONLY with new "Flex"fabric / "Flex"switches probably with an update electronics / firmware on DAC connector. No fisical proprieties differences.
User parnassus have a good research job (with an cable that now are out of market).
I add this info:
JD095C Copper Cable DAC HPE FlexNetwork X240 10G SFP+ SFP+ 0.65mt. have a list price of € 184.00 in Italy and is on HPE networking portfolio started from 14.May.2012
JH693A Copper Campus Cable DAC HPE (not FlexNetwork) X240 10G SFP+ SFP+ 0.65mt. have a list price of € 184.00 in Italy and is on HPE netoworking portfolio started 09.Gen.2017
This is the compatibility list from HPE portfolio May 17 edition for JD095C:
- Series router HPE FlexNetwork MSR4000, HPE Switch Altoline 6900, Series Switch HPE FlexFabric 12900, 5700, 5800, 5820, 5830, 5900, 5900CP, 5920, 5940, 5950, 7900, HPW Switch Flexnetwork Series 5130EI, 7500, HPE Switch Series OfficeConnect 1950, HPE Switch 5130 HI, 5500 B, 5500 HI, 5510 HI.
This is the compatibility list from HPE portfolio May 17 edition for JH693A:
- FlexFabric 5940, FlexNetwork 10500 (this is actually the only devices that NEEDS specifically JH693A cable), 5130EI, 7500, Switch HPE 5130 HI, 5510 HI
Other observation: in the PDF-Specs, updated in March 2017, for 5130 HI and 5510 HI not are present JD095C code, and others old code for 10GbE DAC, only JH693A and others new codes.
