Cloud Managed Networks
  • 1.  Does AOS10 gateway mobility persona can terminate microbranch?
    Posted Apr 10, 2023 10:52 AM
    Hi Folks! I would like to know if in AOS10 using persona mobility for the gateway can terminate the microbranch? My customer previously in AOS8 could use RAP terminate on the controller but in AOS10 using the gateway as mobility role I can't find how to do microbranch work.
  • 2.  RE: Does AOS10 gateway mobility persona can terminate microbranch?
    Posted Apr 11, 2023 02:05 AM
    As for up to the current version of AOS10 it can't. You need VPN concentrator VPNC to terminate microbranch.
    Best, Gorazd
    Gorazd Kikelj
    MVP Expert 2023
  • 3.  RE: Does AOS10 gateway mobility persona can terminate microbranch?
    Posted Oct 16, 2023 10:22 AM
    Hi experts :)
    I am new to AOS 10 and have some questions please:
    • Can a gateway with role Mobility persona terminate Microbranch APs and ViA VPNS ? Aruba Central 2.5.7 and ArubaOS 10.5
    • Do I need one gateway for mobility services WLAN tunneling and another one to be VPNC to terminate MicroBranch APs and Via ?
    Thanks in advance.
  • 4.  RE: Does AOS10 gateway mobility persona can terminate microbranch?
    Posted Oct 16, 2023 11:30 AM
    Hi OthmaneBoulaamane,
    I think nothing changed to this version. you will need a gateway for each type of deployment.   See the last answer that TAC replied to me about this question.
    From: Varghese, AlanSent: Friday, April 14, 2023 3:21 AM
    Hi Herbert,
    Good Day!
    We checked the possible way for deploying a microbranch AP in AOS 10 internally. As per the configuration documents and senario the way to terminate the Microbranch AP it required VPNC cluster.
    The regular way of deploying a microbranch AP scenario requires a VPNC to terminate the tunnel.
    For VPNC configuration please find the below mentioned details.
    https://www.arubanetworks.com/techdocs/central/latest/content/aos10x/cfg/mb-deploy/mb_data_center_vpnc.htm" data-linkindex="27">https://www.arubanetworks.com/techdocs/central/latest/content/aos10x/cfg/mb-deploy/mb_data_center_vpnc.htm
    Please let me know if you have any queries on this.
    Alan VargheseGlobal Solution Center  | Aruba OS
