Location Services
Does Aruba Controller supports integration with Elitecore?
  • 1.  Does Aruba Controller supports integration with Elitecore?
    Posted Feb 24, 2016 12:34 AM
    Hi All,
    can you please help me with below question.
    Does Aruba Controller support integration with Elitecore plateform for Accounting, Authentication and  policy enforcement?
    If yes, Then how it will happen in detail. How msg will flow from controller to Elitecore AAA
    Many Thanks in advance,
    BR,
    Prabhat
  • 2.  RE: Does Aruba Controller supports integration with Elitecore?
    Posted Feb 24, 2016 12:37 AM
    The controller is EAP agnostic so if the solution supports standards based authentication protocols, you shouldn't have any issues.
    Sent from Nine
  • 3.  RE: Does Aruba Controller supports integration with Elitecore?
    Posted Feb 24, 2016 01:06 AM
    Hi Nine,
    thanks for your reply.
    do you have any details call flow or network diagram how it looks like.
    BR,
    Prabhat
