Vlan Numbers, if specified in Virtual APs are consistent between masters, backup masters and locals. On each Master, backup master and local, a numbered VLAN can correspond to a different subnet, or even a different port. How VLANs are interpreted on each physical controller can be configured differently from controller to controller.
A VRRP, on the other hand has a few different functions:
- Between master and backup master on a management VLAN, it determines who is the master
- It can also be used to present a single ip address that access points terminate on, so that the controller with priority will handle all the access point traffc; if that controller goes away, the backup controller will then handle all of the traffic going to that same shared ip address
- Less used is putting a VRRP on a VLAN so that clients that have that ip address as a default gateway can fail over to an opposite controller; typically the VRRP or HSRP ip address is configured on two layer 3 switches that end up being the default gateway of your clients. The controller in most situations is not the default gateway for client traffic.
The short answer is that NO, you do not have to configure a VRRP for each VLAN.
