Thank you! I found the firmware on the portal you mentioned. It's kinda messy all those versions of the same hardware switch.
To help anyone who needs this and came up here, the link below points to the last version of the firmware for this model.
Original Message:
Sent: Nov 25, 2023 12:53 AM
Subject: download firmware HP A5120-48G-PoE+ EI
Don't you have access to Aruba Support Portal (ASP) ?
If not, go there : https://asp.arubanetworks.com
and register.
Then, as parnassus said, you shall access all switches' firmwares and documents.
Frederic MEUNIER
Original Message:
Sent: Nov 24, 2023 06:55 AM
Hi! I'm updating this post because I need the firmware + bootrom for this switch and I can't find it in the links mentioned above.
Can anyone help me?
Original Message:
Sent: Feb 14, 2017 08:22 AM
Friends, I need to upgrade the firmware of my environment HP A5120-48G-PoE+ EI from 2220P02 to R2222P01. I´m trying to find the location in order to download this firmware and complete my task. Could you please provide me the directions in orde to download the firmware or the link?
My best regards
Adriano Porcaro
#firmwareupdate
